Alright guys this is my first "write up" on titantalk on how to do a complete install of 3x3 LED pods! thats right after you read this you will be able to buy some pods and install them yourself ! why pay your hard earned money to some guy at a shop when you can do it yourself !!!!
Parts: Fortunately the pods come with all of the mounting hardware you will need except for 4 washers that you can get from lowes. in the pic are the part #'s
Mounting: now that you have the washers here is where one goes
put the light in the fog light spot
and add the other washer in the back along with the lock washer and the nut
After you tighten everything up make sure the beam is in the desired location.
Wiring to a toggle switch: wiring up a toggle switch is a MUST cause these lights are bright !! Here i have just a simple wire diagram to a switch
pretty strait forward. This is the wire a ran for my switch and pods.
