Bed Rack that will fit using the Utlity bed rails
11K views 9 replies 6 participants last post by  qsilvr99
I am looking to fit a bed rack / rail on my titan for the fitent of a Roof-top-tent.
I don't seem to find any that attach to the existing untlity rails in the bed. Does anyone out there has any success fitting a load bed rack using the rails as attachment ...
#5 ·
I don't belive the weight would be a problem. As per the Manual : Applying loads at angles to the cleats greater than 45° or loads greater than 150 lbs. (header and floor channels) or 200 lbs. (side channels) may cause damage to the channel or bed.
I would assume this is per mounting point ? So if you have a 200lb weight anchored at 4 points, one can assume the load on each point will be less....
