When I use my bluetooth, the speakers seem to have a high pitch buzz to it. When I listen to the radio or nav, I don't get the sound. Is there a way to control the volume of the bluetooth option?
you use the dial on the radio to adjust the volume for the bluetooth when it switches to the bluetooth mode. as far as the buzz it could be interference. do you happen to live by an airport or a military base? maybe your phone just sucks lol.
In addition I just got my 2010 CC LE with Bluetooth. However the audio only comes out of the right front speaker while on the phone. Is this normal now? I just traded in my Armada for the Titan and I'm pretty positive the Armada did not do this.
Check your audio settings first, if you did not do so already. As someone already mentioned you may have a issue with your phone. The center speaker in my truck is where the bluetooth sound eminates from. I also have the same issue when pressing my #3 button on the radio interface. The 'press and feel" just don't seem right.
Audio settings checked, all good there everything in the middle. The audio seems to come from the front center speaker and the front right speaker. With the majority of that audio coming from the front right speaker. It actually makes it a bit hard to hear. I have that same "press and feel" button issue with the #5 button also.
i checked and the bluetooth comes out of, what sounds like, all the speakers......or at least the front ones. it is loud and clear all around. btw, i do not have the center speaker if it matters.
Yes it does matter. I was at the dealer and they actually tried 3 different Titans. On the Rockford System with NAV and the center speaker...the audio does only come out of the far right front speaker. On the other Titans it came out of both front speakers....not sure if it was really designed this way...or a software error that just wasn't caught. I do know mine isn't the only one that does it.
I had a similar rattle/buzz that I heard mostly when listening to talk radio and Bluetooth phone calls. It finally put me over the edge and I tore into it and found two sources of rattle/buzz. The first one was the trim around the nav screen. It is fastened to the larger plastic bezel that includes the vents by melting some plastic tabs that protrude through the larger bezel. When I tapped on the speaker cover I could hear some rattle so I mixed up some epoxy and worked it in the gap (from the back side of course) and that semed to get rid of it. The second thing that I found was that the fiber board edge of the speaker buzzed against the metal speaker frame that holds it. I put blue locktite around the edge to secure it and voila no more buzz.
It was designed to come out of just the right. Most (not all) do that. Even my aftermarket radios do. I think the thought behind the design is it would be more natural, like someone in the passanger seat talking.
As far as the buzzing. Try someone else's phone. What year truck?
Related Threads
Nissan Titan Forum
posts
4M
members
177K
Since
2003
Nissan Titan Talk Forum is a community for truck owners to discuss the Titan Cummins, Warrior, Midnight Edition and more!
