So, it typically only happens when someone mods their truck, but yet is still a "poor Nissan design"?
Hmm, then why all the owners with STOCK trucks chiming in with problems
I've seen you write this a few times, and each time you write it you're as wrong as the time before. To claim that the shock is "destroying itself" by topping out is just silly and almost libelous. The shock is the limiting factor for suspension stroke on our trucks, thus it's designed to top out. That's why our shocks have stoppers in them that are separate from the valve assemblies. Ask Greg, I'm sure he's cut a few open in his time.
Yes, I'd say he has: http://www.titantalk.com/forums/739858-post6.html
also:
PrerunnerGreg said:
On the 08's you need to grind a little bit on the drivers side coil bucket. It seems as though Nissan has the frames built on a new jig and there is a small clearance issue now (the coilbuket is welded a bit higher on the frame now).
Do you have any data, anecdotal or otherwise, to demonstrate causality between top-out and the shock "destroys itself"? If not, I'd seriously consider not implying a truth where one cannot be proven.
