The rims are forte f-51. They are 20 x 9. I don't know about the offset yet. I am planning on getting the leveling kit but i want to know how big of tires can you run on these with the stock suspension.
MY TRUCK IS LOWER 3/2 ON 24's NO PROBLES:thedevil:titanmike said:The rims are forte f-51. They are 20 x 9. I don't know about the offset yet. I am planning on getting the leveling kit but i want to know how big of tires can you run on these with the stock suspension.
Looks like they have an 8" width and 8.5" width, and both are available in 5" b.s. So if you are running the 8.5" your rims are out an inch over the stock ones, but only half an inch with the 8" wide IIIs. The pinch weld mod looks easy though, and you might need to take off just a bit.huskyfan said:interesting. i have 305/55-20 Nitto Terra Grapplers and a PRG mini lift. Tires are mounted on Centerline Stingray III. I have minor rubbing on the inner front splash guards and fenders. i don't really want to do the pinch weld. It rubs, very slightly, on the fender liner too and max lock on the turn
