Does anyone know anything about this kit?
1.5K views 24 replies 10 participants last post by  FishnAlaska
PRG Products
I'm on a budget and want a leveling kit for sure but then I found this. Feedback would be fantastic from people who have or know a lot about this kit. Thanks!!
#2 ·
that's a simple kit to install and will give you an inexpensive lifted look without needing to change out the control arms or other front end parts. It will not relieve the sway that our trucks inherently have but most of us live with it as to owning a Titan.
#3 ·
PRG is the best, but you can get spacers and blocks on ebay for about $85 less.
#13 ·
I spent $130 on my ebay front spacer and rear block , full billet aluminum, just like PRG, I'll pm you a link on who I got them from after I get home from work.
Reactions: vilim12
#15 ·
The only other opinion/idea I would throw your way is instead of getting the spacer, possibly look at getting the Bilstein 5100's. If you get them and put them on the middle setting, you would get the 1.5" of lift. With a 1.5" lift up front, you also will not need a rear block, unless you want to maintain the "rake" that the Titan comes with (the rear of the truck being higher than the front). Hope that helps!
#18 ·
Thanks everyone! I'm gonna check out all of this stuff. I want the 5100s but a leveling kit is more in my budget currently. Does anyone know if it would look awkward if I got the level then didn't get bigger tires. I'm not at my truck now so I can't look at the size but I will post that ASAP
Sent from my Autoguide iPhone app
#25 ·
I'm running a little shorter but wider tire than stock, I think it looks fine, but eventually I want to move up to a bigger tire, most likely a 275/70/18 BFG AT TA
#19 ·
My truck has stock tires and wheels ant it's leveled. It looks just fine like that.
#20 ·
I have the leveling kit up front with the bilstein shocks and a 1.5" spacer in the rear with 275/70/18 and it looksfine. A lot of guys don't upgrade wheel size until they get a 4" lift or more due to rubbing with out the PWM.
Sent from my HTC Sensation 4G using AutoGuide.Com Free App
#21 ·
All these guys are giving you great advice, the only thing I can add is stay away from the welded steel leveling kits, quite a few guys have issues with those (stripping threads, bending and stuff) pretty much any solid billet aluminum kit on ebay with a lifetime warranty on Ebay will work just fine with no issues.
Reactions: Quartz
#24 ·
I've seen 2 or 3 on here bent and at least 2 where one or more of the bolt holes were stripped. I also have a buddy here in Hawaii and he had to remove his because it bent somehow.
I will never put one on my truck nor recommend it, you may have gotten a good one and I hope it continues to work for you.
All good advice. Billet kits aren't any more expensive and the piece of mind they give is priceless.
Reactions: *SocalTitan*
#23 ·
