Does anyone know how to "relocate" the left power port elsewhere?
908 views 6 replies 3 participants last post by  silvernik25
So, I have my XM Roady2 placed between the shifter and the left power port (remember them being the cigarette lighters???). I have the Roady plugged into the right port. I want to be able to use the left power port for PSP, iPod etc. I know there are multi port adapters, but they are too big to plug into the right side port.
Is there a way to "relocate" the left port to somewhere else?
Thanks!
#2 ·
You can tap the circuit for the desired port in the in-cabin fuse panel using a mini-blade add-a-circuit or fuse tap and then either mount an additional port that uses the same circuit in your desired location, or hard-wire a device. (staying under a combined total of 15 amps on the circuit).
#3 ·
I used a fuse tap and wired a new outlet behind the dash. It's pretty simple just plug the fuse tap in an existing fuse slot and run the wire anywhere in the titan you want (Beside the seat?) then run a ground wire from the new outlet. total cost $10 to $15
#4 ·
Thanks guys. I don't know what a fuse tap is, but I can probably figure it out. I just don't want to fry anything :imwithstu
#6 ·
