Fording Depth
1 reading
11K views 21 replies 17 participants last post by  JTD
I've got a big hunting trip planned this year and it requires crossing several small creeks ranging in depths from 18" to 36" I'm hoping crossing these won't be an issue but there is that electric fan on the bottom part of the radiator. If this is submerged will it kill this fan?
#2 ·
that's a good question. The fan is obviously exposed to the elements on a daily basis but being completely submerged....hmm I would think at the very least it would be a good idea to unhook the connector going to it so it doesn't turn on while being submerged...
36" of water.....isn't that a little too much to be driving through anyhow??
#4 ·
36" is a bit much, but thats just a guess, I've been in the crossing when the water was almost to the top of the wheel. I was a spectator when my dad crossed through in the chevy. Its not a long crossing either, just a quick in and out.
#8 ·
they should only warp if they are hot before you get them wet. if you are going offroading through creeks, the brakes shouldn't be used all that heavily (vs. onroad driving), so they should be fine in the water.
#9 ·
How hot are your rotors when you go to the car wash? Do you worry about it then?
Hey Gizmoii, Too bad you got a Black one.....I hear that DeepWater is better for fording creeks... :jester: :huh:
#10 ·
the titan wont fit in most car washes = )
#11 ·
My personal rule of thumb is never go deeper than half way up the hubs, any deeper and you run the risk of getting water into the diff through the vent's.
Of course in an emergency I'd go deeper, but I would be draining and changing my diff fluids and transmission as soon as possible.
#12 ·
dhaessig said:
...and you need to keep the exhaust above water.
why? muffler warpage?
#14 ·
You can always extend the vent line up into the engine compartment where it will be above water. Also, your mufflers can go under water if the engine is running, but if you shut it off your screwed.
#15 · (Edited)
true, but would look a little suspicious if I ever took it in for warranty work :jester:
#16 ·
Hey Best, I drove mine right into a car wash today. I got out and sprayed the helllll out of my whole truck...disc brakes included. It is really hard to keep the spray off of the brakes...stupid wheels are see-through. I didn't hear any sizzlin' or anything though...so I think that I will be okay. :huh: Also, I try not to brake on rainy days...just so that I don't get the rotors hot, and then have that rain spray up on them...and I avoid puddles like the plague :fart: Oops...'scuse me...that one slipped out.
Keep your powder dry...and your rotors too... :rofl:
:cheers:
#17 ·
I live in SW Colorado and play in rivers and streams all the time.... please consider that if you have a fairly swift current you could float the truck. I think 36" is pretty deep for a stock truck.
And all the points above about differential, etc. Better look things over very carefully if you are really going to cross 3' and prepare the vehicle. Hope you have lost of $$$.
#19 ·
36 in. is too much, unless you don't mind flooding the cab. I've gone thru water almost to the top of the tire, so i guess 28-30 in. and that was fine . I wouldn't worry about the fan getting wet, when you figure what happens to it during a down pour. I've been very impressed with the titan off road, as long as you don't sink it you should be too.
#20 ·
I have run my frontier through water above the tires plenty of times. I have 31" inch mudders and no lift. As for the warping rotors. I Bash through all sorts of puddles and floods and standing water and smoke always billows out from my front wheels. My brakes work great and no signs of warpage.
#21 · (Edited)
Nissan should offer a snorkel option like they did on their Nissan Patrol, [sort of like an old Land-Cruiser]; my Father-in-law had Patrol, and it was setup for one on his.
#22 ·
I live and hunt in Florida and have had my 94 and 88 hardbody in water over the headlights temporally and plan to have my titan at lest to the top of the tire fording streams/holes, but these holes I know have hard bottoms in them.
My Nissans in the past has made some of the best water resistant trucks and I sure hope its’ the same with the Titan. The old 88 went though streams that killed a JEEP and Toyota.
With the Nissan pulling air between the fender well sheet metal and not though the grill and bumper make getting water in the intake difficult but defiantly not impossible.
Have never had problems with water in my diffs’ or pressure with exhaust, but the holes I cross are never over 2 truck lengths and I always maintain a steady forward motion.
All that said I’ll be the first to tell you I’ve locked my truck in four wheel drive backed off the road and turn around if a hole looked too deep and/or too buggy.
Never hurts to wear old boots or pull on wader to walk a hole or steam out and find out how deep it is before putting your truck in it.
