Header Installation How-to
42K views 41 replies 25 participants last post by  peanstein
#1 · (Edited)
I finally got around to installing my newly purchased Doug Thorley ceramic-coated shorties this weekend. Just thought I'd give a step-by-step of the process for those who are considering the same install. Instructions are available online from Stillen, but they are not very detailed and the instructions are mainly for 2WD Titans.
I would have included pics, but it was dark and I only had my iPhone to take pics with. My hands were greasy so that wasn't going to happen.
Required tools:
Jack stands
Jack
3/8" Socket wrench
3/8" Short (Stubby) socket wrench (not required but useful)
Various 3/8"-drive sockets (10, 11, 12, 14mm)
Various 3/8" socket extensions (2 - 6" ext., 1 - 4")
3/8" Socket universal joint
Various sized box-end wrenches (preferably with a ratcheting end)
O2 socket or equivalent crows foot
Small piece of 2x4 lumber
Rubber mallet (not 100% necessary but might prove useful)
Mechanic's Gloves - I consider this a MUST HAVE if you don't want scratched and beaten knuckles (trust me)!
CHEATER BAR - A DEFINITE MUST HAVE - 80% of the bolts will be very difficult to remove without the use of a cheater bar. A piece of 1" pipe or square tubing around 15" long will work. Anything that can slip over the end of your socket wrench for more leverage.
Required tools for shorty header installation:
Reciprocating saw or grinder with cut-off wheel
Die Grinder or Dremel tool (for de-burring and cleaning the surface of the cats)
Flux-core or MIG welder/equipment
Step 1:
Park truck near a useable electrical outlet. This might not be needed with a longtube installation but if you are installing shorties and plan on doing the welding yourself, this is not something you want to overlook. Chock rear wheels and apply parking brake.
Step 2:
Slightly loosen front wheel hub nuts. Jack up the front end of each side of the truck. Jack points are just behind the wheel on the frame of each side. Once each side is up, support that side with a jackstand. I placed the jack stands just behind the stock jack point.
Step 3:
Once the vehicle is supported, remove both front wheels. Then remove the wheel well liners by removing screws and any clips holding them in. Keep each set of screws and clips in a labeled ziploc bag for safe keeping.
Step 4:
Unbolt both b-pipes on the exhaust. There are 2 bolts on each end of each pipe. It is not necessary to remove the O2 sensors from the b-pipes. For now, leave the b-pipes attached...only remove the bolts. Save and label them.
Step 5:
Remove both skid plates from underneath the engine. This is pretty self-explanatory, just unbolt them. Again, save and label your bolts.
Step 6:
Some people have recommended dropping the front differential at this point. I opted not to and it worked out just fine. It would probably make accessing some bolts easier and would give you more clearance to jack up the engine, but to me, it wasn't worth the trouble. If you choose to do this, you are on your own!
Step 7:
Cut a piece of 2x4 approximately 3"x5". You will use this to jack the engine. Crawl underneath the engine and look for an opening on the front side of the differential. You'll see a flat portion of the aluminum floor pan. This is the jack point for the motor. There is a ridge towards one side of the pan. I chose to cut the 2x4 so that it fit perfectly on the flat part beside the ridge. Make sure that your 2x4 and jack will clear the power steering line that runs through the area. I used the stock jack and had to use a cinder block to achieve the height needed. Use common sense here.
Step 8:
Once you have decided on jack placement, place the 2x4 between the jack and the pan and jack up the engine slightly to relieve pressure on the motor mount bolts.
Step 9:
Look directly above the front differential on either side of the engine block and you will see a black piece of square tubing going from the frame to the engine block. These are the motor mounts. A flange on the end of the tubing connects the motor to the frame via 4 bolts. You will need to use your creativity to access these bolts, especially with the driver's side which is slightly more concealed. I used a combination of extensions and a universal joint to break the bolts and backed them out a few turns. After being broken, they should turn easily by hand if the motor has been supported enough by the jack to take the weight off of them. Back them out until they almost come out of the block, then turn them back in a few turns. You can remove them completely, which would allow you to jack the motor up more later and while this might make some things easier, it could be difficult to get them threaded into the block later. I opted not to remove them.
Step 10:
Now that the motor mount bolts have been backed out, continue jacking up the motor, keeping an eye on the motor mount bolts to make sure that you do not jack the motor up farther than they will allow.
Step 11:
Once you have reached the maximum height allowed by the bolts (for me it was around 1 to 1-1/2"), you may now begin to remove the heat shields. Unbolt them from the exhaust manifold and remove them from the vehicle. They can be somewhat difficult to pull out and some people cut them into pieces. I found that I was able to get them out in one piece by bending them flat with my hands and a pair of pliers. It took me maybe 20 minutes for both shields.
Step 12:
Now that the shields are gone, remove the O2 sensors from each manifold. The easiest tool to accomplish this would be an O2 socket, available at your local auto store for around $10. I used a 22mm crows foot, which worked perfectly. If you've never seen one, it is basically a box-end wrench with a square hole for a 3/8" ratchet. I used an extension to reach the sensor. Once removed, rest each sensor in a safe place. I placed them on top of the motor in a stable position. Be careful not to hit the delicate tip on anything.
Step 13:
Remove the bolt holding in the dipstick tube. You will not be able to fully remove the tube until the exhaust manifold is free.
Step 14:
Unbolt the passenger side exhaust manifold from the motor. Again, you will need to use your creativity here. Some bolts are hard to reach and will require the use of socket extensions and a universal joint. Once the bolts are removed, pull the dipstick out of the engine block. Then pull the manifold away from the block and move it toward the front of the truck to pull it away from the b-pipe. Now rest the b-pipe on the crossmember that lies directly beneath it and move it slightly to the side to allow the exhaust manifold to be removed through the space that was previously occupied by the cats.
Step 15:
Repeat Step 14 on the driver's side, omitting the step for the dipstick tube.
Step 16:
If you are installing long tube headers, which replace the front cats, skip to Step 19. If you are installing short tube headers, take the stock manifolds and, using a cutoff wheel or reciprocating saw, cut off the catalytic converter 3/8" above the weld that connects it to the exhaust manifold, just underneath the O2 bungs. Mark each cat "driver's side" and "passenger side" so you don't get them mixed up.
Step 17:
Install the shorties without cats onto the motor using only 3 of the 8 bolts. Once they are on, jack the motor back down. You may choose to tighten the motor mount bolts to make sure you are aligned properly, but I just eye-balled it to make sure the mounts sat flush with the engine.
Step 18:
Once the motor is down, place the cats into the flange of the header and align with the b-pipes. Don't skip bolting everything up here, as it needs to be aligned perfectly before welding. Once everything is aligned and bolt it up, triple-check alignment, disconnect the truck's battery, then tack weld the cats to the headers. I put three tacks on each header and it held fine. Jack the motor back up. Now you may remove all of the components again and complete your welds.
Step 19:
You're almost done! Installation is the reverse of removal, but for sake of order, I'll run through it quickly. Reinstall exhaust manifold gaskets and headers and o2 sensors (long tubes may require lengthening the 02 wires), reinstall the dipstick tube, connect the headers to the b-pipes, lower the engine (still allowing the jack to support the motor slightly), tighten motor mount bolts and remove the jack, tighten all bolts on the b-pipes, reinstall wheel well liners and skid plates, bolt on the wheels, lower the vehicle from jack stands and connect the battery.
Step 20:
Crank her up and enjoy your improved power and throaty growl!
Was this installation tough? Yes.
Did I curse and swear? Yes.
Did my fingers bleed? Yes.
Did I cry? A little. :crybaby:
Would I enjoy doing it again? Can't say I'd look forward to it.
Would I do it again if it meant saving $600 in labor costs? You bet your arse I would.
:cheers:
#2 ·
Nice write-up johndoby, thank you.
L
Reactions: domybest
#6 ·
If you want long tubes, you have NISMO, Stillen and the upcoming (not available just yet) Doug Thorley long tubes. They range from $599 (Stillen on sale) to $729.
The headers I bought are short tube Doug Thorleys. They are ceramic coated and I paid $350 plus $40 shipping. I could probably hook you up with the guy I bought them from. Your only other decent option for short tubes are JBA's. Folks have had positive experiences with them and they can be had for about the same price as the Thorleys uncoated. Coated, they are more expensive than the Thorley's.
As far as power difference, it is fairly noticeable. I used to back up my steep driveway in reverse to hear my exhaust leak better. After I got the new headers installed, I decided to try it again to see if my welds were leaking at all. Instead of a ticking exhaust leak sound, I heard the sound of my tires squalling, as I immediately broke traction. So, yes, the difference is noticeable. I have a feeling that if I remove the WOT restriction, I'm going to be blown away.
#7 ·
I'm going to try to take some pictures of some of the key parts of the install... Jack points, motor mounts, etc., but to be honest, pics are only going to help so much. I went by written directions and was rarely confused without pictures. The Stillen instructions have some useful photos, however.
#11 ·
I just realized I left out the single most useful tool for this installation... A CHEATER BAR. I would not have been able to break loose probably 80% of the nuts and bolts without a cheater bar. I used a piece of 1" square tubing cut down to about 15" long, but a piece of 1" pipe or anything you can slip over the handle of your socket wrench will work. I'll edit the original post now as well.
#12 ·
Thanks for the write up... you made it seem easy :D
My manifold leak is really starting to get on my nerves and I am going to have to do something about it, soon! I'm out of warranty so headers here I come. Thanks again for the step by step instructions.
#13 ·
It really wasn't a hard install...it was a LONG install. This was mostly due to the short tubes, and having to fit and weld them. After driving mine for a few weeks, I started hearing some wierd exhaust notes, so I took the b-pipes off and my cats had come apart. They were fine when I performed the install. I would highly recommend going with long tube headers. Its going to make the install tons easier and you wont have to worry with the stock cats. If you stick with shorties, at least gut the cats or make a test pipe instead and leave the cats in the b-pipes.
#14 ·
I plan on going with LT headers. I don't think I'm going to make the DT Group buy, but I may still get them even if I don't make the GB.
Any video of how yours sound?
#16 ·
Nice write-up.. Could use pics... I don't care what anyone says, they help, even if you know where the bolts are and where to jack off your truck..... :D
#18 ·
The whole point is not to show that you did something... or tell that you did something. If that's the purpose, then the standard instructions would do just fine.
I do the write-ups to help the person who may have a bit of mechanical aptitude, but not have the confidence to do it themselves because they never have. It helps tremendously to have pictures of what's involved so the person can decide if it's something they can tackle themselves. Mainly, it's to offer the self-confidence to do it and save money in the process by not paying a mechanic... They end up with a sense of accomplishment and pride in the fact that they did it. Perhaps they go on to do other things that they would never have tackled without someone showing them how. Nobody was born with this knowledge. We just acquired it along the way, by either being shown, or by screwing up and learning from our mistakes..... That's how we learn.
I'm not trying to poopoo your write-up, by any means... It's great and will help those knowledgable to attack this project. I'm just offering my view on the pics/no pics issue. Thanks again!
#19 ·
My initial intention was to include photos in my writeup, but my camera died, I wasn't about to get my iPhone greasy and the majority of the installation took place at night.
With that said, I still think that this is the best writeup on header installation, for the following reasons:
1) No other write-up exists! (other than Stillen's which brings me to my next point.)
2) It's the only write-up that includes factors from 4x4 installations.
3) It is written with the do-it-yourself-er in mind. Stillen's write-up is very bland...for instance, their step on removing the exhaust manifold from the engine simply says (from memory) "Remove exhaust manifolds from the engine." Gee, thanks for the input there, Stillen!! How many years of R&D did it take to put that kind of direction together?! On the swing-side, some of their other steps are even unnecessary, like removing the engine mount bolts completely from the block.
3) Other write-ups aren't going to offer time saving tips like drinking beer, using a cheater bar or remembering to park your vehicle next to an outlet if you plan on welding...as well as other things that are EASILY overlooked and DEVASTATINGLY time-consuming to correct..especially the beer drinking. Imagine being almost done and realizing you haven't drank a single beer...you'd have to start all over again!
4) I'm sexier than Stillen.
Now I know that somebody is gonna jump in and say "This isn't the only write-up! I've seen one on so-and-so website!" I'm sure that somewhere in the bowels of the interwebs lies a write-up that it is quite possibly better than mine. The thing is, I couldn't find one...and believe me when I say I LOOKED.
I can assure you the purpose of this thread was not to showcase what I've done, as was seemingly implicated. I wrote this for the purposes of giving those who want to attempt this themselves something easy to follow...sharing information learned through my own mistakes. I do recommend that they research information from other sources and combine the knowledge gained to find the approach most suitable to their knowledge level. I never intended this to be a confidence-inspirer. If a guy reads this and still doesn't know if he is experienced enough to attempt it himself, then he probably ISN'T experienced enough to handle it.
You may not be poo-poo'ing on my write-up, but at very least, you're stinkin' it up! :hahafu: I'm still not mad at you though, seeing as though you have the sweetest avatar on TT. I've sat there for (longer than I want to admit) just staring at it in awe. Anybody with that sort of taste can't be ALL bad. :rofl:
#20 ·
nice write-up, with or without pics it helps a lot.
#23 ·
I wish u lived in Colorado..
#28 ·
Yeah, I have nismo cat back with stock manifolds-cats & it's pretty dang loud.
So loud, that I'm considering going back to stock.
I'll see how I feel about the noise after my vacation end of Sept.
#29 ·
Loud? BUAHAHAHAHA!!!!!!
Try the Nismo catback with JBA LT headers and Maggotflow Hi-flo cats in the B's...
You'll set off car alarms. (Ask me how I know...) :eyebrow:
#31 ·
Unless you are flexfuel, yes. Your AFR will be off and most likely enough to be in the danger zone. Tuning is certainly highly recommended... at least if you want to keep the beast alive.
#34 ·
Warning first post here: I'm better with a wrench than a mouse.
I'd like to start off by saying thanks for the wisdom that has been shared here! There are many tips on this thread (and a few others) that are time savers. I have been planning this repair for some time and a large hail storm provided the cash. Thanks out to State Farm. Granted, my roof will never be the same, but it was worth it!
I started off by spending 2-3 hours removing the wheels, inner fenders and heat shields to allow for a week or two of PB Blasting on the header bolts and all exhaust bolts. I was able to get both heat shields off by cutting around the O2 sensors and doing a little bending. The passenger side came back and out the bottom. The drivers side came forward and up out the top.
I ordered with the Cajun B Stage 2 Kit and added the Ultraquiet resonator. Everything arrived pretty quick and neatly packaged. Jeff was very helpful throughout the process responding to EVERY text or email sent - and there were several. I have to thank him too for many time saving tips! Before you order somewhere else to save a few bucks make sure they 1-have them in stock and 2-are willing to answer your questions. The kit is not cheap but I felt like I got what I paid for and then some! I have a friend who got a cheaper kit to save money and it's nothing like this kit, hands down worth a little extra.
I gathered the tools I don't own like the O2 sensor removal kit, long extensions, breaker bars, and quality name brand wrenches. I figured if I was going to break a tool I might as well get a free replacement. The long 1/2" extensions were most useful for the motor mounts. It took all of it to get the drivers side motor mount bolts loose-that front/top was the worst bolt on the entire project!
The old exhaust came off pretty easily from the first cats to the tip. I used some heat on the O2 sensors and they popped right off. The passenger side was fairly easy. The drivers side header wasn't too bad it was the lack of access to the motor mount. I did not have to remove the motor mount or its bolts, just loosen them and jack the motor up about 1-2" Slip the old header and gasket out and the new ones in. I used a snap-on 14mm straight wrench on most bolts and the offset wrench on the others.
My recommendation is to double check the clearance on the drivers side header and the motor mount. I knew it was close but bolted it up anyway. Then realized it's VERY close. I can fit a credit card through it with some clearance but I'd like more. It's not hitting or making any noise at this point. If I could do one thing over it would be to grind some of the front/top portion of the mount off before re-installing. I hope I don't have to go back and do this later....I'll be monitoring it closely for a few weeks.
Overall I had around 16-20 hours working on it off and on for three days.
My first trip was to the local muffler shop to weld all the joints and remove the clamps. $50. May not be necessary, but I think it was worth it.
I've been working with Joe from Cajun B on my Uprev tune. Wow, don't skimp here either! This tune and the features of the software are incredible. Joe has also responded to EVERY text and email sent. A huge thanks to him too!
My truck is noticeably better. I don't know how many horses it added but I do know that it pulls my 3 horses much better. The bottom end power is as incredible as the top end. It's like driving a whole new truck!
I'm going to try to add a few pics of the tools I used, the clearance on the drivers side, and the final install. The clearance pics aren't very good quality since they look like there is contact, but its the angle of the camera. Limited to 5 tho.
Again, thanks for all the help on here and from the guys at Cajun B. Thanks to State Farm for financing. And last but not least, good luck if you're headed down this path.
Cheers,
Matt
#35 ·
How were the manifold nuts? Any issues removing them?
#36 ·
The manifold nuts weren't too bad. I sprayed them with PB Blaster before I drove it for over a week to help free them. The passenger side was fairly easy to get to. The driver's side was tough on my 4x4 due to clearance issues but I was able to break them all free pretty easily with a cheater bar or a small hammer. They all came off without issue. I'm not saying it was easy, but nothing broke besides the skin on my knuckles a few times!
The drivers side motor mounts were the worst, again due to lack of access.
#37 ·
Just did mine word to the wise it's all in the prep work with the PB blaster. Also don't make same mistake I did when you goto flash the base tune. Make sure the antivirus software is OFF mine was not an bricked my ecu fortunate for me I live one hour from uprev sitting here now they are recovering it. Joe was he biggest help in this process he called them an told them the situation an spent about 2 hours emailing possible solutions before he called cant express how good Cajuns customer service an patients are hats off to the Cajun fellas.
#38 ·
I had a shop install my JBA longtubes, I am running down the P2A00. the next step is changing the header gaskets and yes I will be using OEM and that is what was supposed to be used on the initial install we will see. OK can I slip the headers back to R&R the gaskets without lifting the motor??????
Thanks Bobby
