Hot Transmission temp while backing up camper
1 reading
7.3K views 9 replies 8 participants last post by  Smoke05
I posted this question before, but it got placed in the wrong category.
While backing my 35', 7500 lb travel trailer the transmission temp gauge went over to the white tick mark on the right. When I saw it, I shut down the motor and let the tranny sit and cool down. After a while, I started again and the temp went up. I put the truck in neutral and reved the motor to get air over the intercooler, the gauge went back down.
I am backing about 90 feet with about a 5 degree or so incline.
While driving normally and backing into campsites i don't have this issue.
My question: Is this happening due to the lack of air flow over the inter-cooler while backing? I know its a lot of strain on the entire truck to put the trailer in its spot at home.
Is there a solution of putting a fan on the inter-cooler itself to keep the fluid cooler?
Any advice is welcome and appreciated.
#2 ·
Reverse gear gearing is almost the same ratio as 2nd gear. 5 percent isn't much but when you add that load it is.
Some people walk like an Egyptian. I walk like the pope with a cane.
#3 ·
Is that the dry weight of the trailer? You may be pretty heavy with gear loaded in it.
Have you changed the tranny fluid recently?
It makes sense it will hear up more while backing since when driving on the highway you have airflow across the radiator, but won't have this when backing.
It is odd that it heats up that quickly though.
#4 ·
If I'm in an area with a dirt or gravel surface (not pavement), I put the truck in 4-wheel drive, low range before backing with the trailer. This takes some stress off the transmission, and it seems to make it easier to aim the trailer.
#8 ·
This is what I do also. On a 4x2 I don't know how to work around the problem.
#5 ·
Besides that trailer is most likely over the max weight compacity for a 1/2 ton ( just length alone you are a brave person).
Backing up with no airflow and a heavy load is a recipe for transmission overheating regardless of the size of the tow vehicle. You can try to use 4wd and be quicker or get a cooler that has its own fan might help.
#9 ·
It's not just a Nissan problem, I had a 1ton Dodge that did the same thing. Reverse gears are high and add the lack of airflow means a hot transmission.
#10 ·
Something isn't right. Sounds like you were running hot prior to backing it up. 90ft is not really that far for the temp to jump like that. Maybe the gauge is off? If it doesn't shut down or redline just back the sucker up and if you want, let it idle and cool while you unhook.
The only time I had an issue with tranny temp backing up was after a ton of towing real steep hills on approach and inside a campground at low speeds. I was pretty hot per the gauge before I even started to back it in. Even then it didn't overheat, but was def pushing it.
