Before I get started, I have searched all the threads and it seems that if people got theirs resolved, they didn't post what was ultimately wrong, or their cause for misfire has been eliminated as a possible cause of mine. Here's the story:
First misfiring occured after cruising on the freeway at relatively low RPM for about 50 miles. Everything was fine until I exited. When I slowed down on the exit, car started misfiring and CEL started flashing. Reset CEL and computer and misfire went away. Happened again so I took it to the dealer. Changed plugs, checked coils, misfire was gone. Came back a couple weeks later. Took it back to dealer, they ran compression and vacuum tests. . . aok. . . looked at everything else they could think of, put her back together. . . misfire gone. . . Happened again. . . same thing. . . no solution . . . this happened 4 times with the dealer, so next misfire, took to independent mechanic who noticed exhaust leak at manifold. Replaced gasket and hoped misfire was caused by bad air/fuel ratio due to exhaust leak. . . also had him check the cats . . . they were fine. . . misfire gone. . . came back shortly thereafter. . .
I can actually make the car misfire now. . . If I drive at about 1800-1900 rpm for an extended period of time, the engine starts to feel odd, then starts to misfire and CEL comes on and starts flashing. . . code is now for misfire cylinder 2. . .
So knowing that cruising at low rpm causes the misfire, i tried shifting manually around town and running it at a higher RPM. . . MISFIRE STOPPED. . . CEL turned off!!!! As long as I'm keeping the engine wound up, it runs fine. . . start cruising and driving really mellow in "D", then misfire inevitably returns. . . CEL light turned back on and misfire returned after driving it normally. . . wound it up again, driving at high RPM. . . light still on, but running smooth. . .
Here's what's been eliminated:
ECM - Recall already performed
Plugs - replaced
Coils - Inspected and tested by rotation and fine
CAT - Inspected and fine
Compression - tested and fine
vacuum - tested and fine
Fuel Lines - Cleaned
Been at the dealer at least 4 times and opened a case with Nissan USA . . . no results. . .
Anyone have any suggestions???????
Truck is completely stock. . . 2005, 95,000 miles and VERY WELL MAINTAINED. . .
Plugs - replaced
