my 09 titan needs CAM bolts ??
1 reading
1.8K views 9 replies 6 participants last post by  TitanGuy09
ok i have been having a problem with my truck on the highway following grooves or i guess wandering. but the steering rack i ended up fixing my problem with it needed adjusted.:eyebrow: and now i had my brother (A mechanic) look at my front end and found my right wheel is leaning out on top more then the left side. so that brings me to say i need to get PRG cam bolts??? did anyone get cambolts for their 09. is there any other cambolts to get other them the moog or prg? and yes i leveled it then had it aligned at a shop. and i didnt get a print out of the results cause he didnt have the laser one.... my mistake to go there anyways
#2 ·
It's different for just about every titan, but most of the time anything around or over 2.5" will cause positive camber to some extent. I had a 2" leveling kit and when the shop did my alignment they said it was close to being out of specs. It's a good upgrade either way. Check your local dealership and rock auto if you dont want to go with prg.
#3 ·
Not that i dont want to go with prg. I just dont like 70 for 4 bolts.
My right tire is out almost a 1/4 of an inch on top more then the left
#5 ·
I guessing my alignment is out. But im not gonna say our measurements are perfect or way off but cant hurt to get it realigned with a laser setup right?
#7 ·
Reactions: allbtitan
#8 ·
My 09 Titan started wearing the front tires on the inside so I had it aligned at a firestone I used to work at. They told me I needed cambolts in order to fix the problem. I was lucky to know a service guy at the dealership I bought my truck from, so he had them put in the cambolts and do an alignment for free.
#10 ·
just bought a set from a member for 50 shipped brand new not used. prg ones too
