My 4wd seems noise and vibrates a lot when engaged. Sort of makes a groawning sound.
Is that normal?
Should it be as quiet as 2wd?
Is that normal?
Mine seems to make a little more noise when I turn too. I hear it on snow or whatever.helomech said:I can't tell mine is engaged, unless I try to turn sharp. It still doesn't make noise, just harder to turn.
jmeyer said:Mine was very quiet when I purchased my truck. Over the last 5,000 miles it has been getting progressively louder. I have mentioned this to my service manager ans he stated that it is normal and his Titan makes the same noise mine does.
I call shenanigans on the whole deal. I can't imagine 4x4 being quiet then getting loud normal!
Then add about a quart of wet sand to the mix and run it at about 30 mph. I know exactly what you are trying to explain....I think.midnightmadman said:I was trying to think of a way to describe what it feels and sounds like. Imagin a differental completely dry..
No difference in sound between 2 and 4 wheel drive, even turning.StuntDriver06 said:yes mine does it too... its like a loud hum that can be felt in the floor, i notice it when i accelerate... seems to be normal i think.... is there anyone that can say that the noise in 2wd and 4wd isnt any different while going straight?
is the same true when you step on the gas?helomech said:No difference in sound between 2 and 4 wheel drive, even turning.
i agree as this has been my experience....x2thez said:OK, I think we are addressing two problems here. First is the noisy 4wd, and I must say that on my 2004, I can tell that it is engaged, but I have driven a few others and it appears to be normal between them.
Secondly about the disengagement, in order for it to disengage there has to be a break in the driveline, essentially a difference of speed between the front and rear axles. I occasionally have had a small problem doing this but nothing to cry about. Whenever I want to disengage I speed up quickly and then let off, enough so that the weight of the truck will shift and it will unlock each time. The other way to do it is to turn the wheels, but hard to do while driving 65. I can engage at any speed, as well as disengage, but it doesnt fully unlock until there is a difference in speed between the front and rear axles. I hope this helps to explain things. OH by the way I have the stock 18" oem wheels and I dont see how an OEM wheel or not woudl make a difference, UNLESS your front tires are a different size, style, or treadpattern than the back.
