What size are the bulbs to replace the license plate light with LED? I figure one of mine went out so I might as well do the change now. Thanks.
I did this when I first bought mine to hardwire my GPS. Be careful, the tabs that hold the console up break easy. If they break, you can use plastic epoxy to glue them back on. Dont waste your time with super glue.If your afraid of breaking the little tabs, you can also pull the whole assembly down from the roof, a couple screw and a little tugging will pop it right out, it's also the only way to change out the "mood light".
