Hey guys,
I have two problems. Recently I've had my tailgate pop off its base twice. Once while I was driving with the tailgate open, I got to where I was going I found that the tailgate had jumped out of the left side catch and was about to fall off the right hand side. This could have result in the tailgate basically hanging from the cables. I put it back on, and didn't have any more problems until I went to open my tailgate on a jobsite that has a very, very steep driveway. I opened the latch and went to let it down and the whole thing just dropped off the truck and was hanging across the bumper by the cables. Any thoughts....
Second more serious problem was today one of my workers got a tracked Cat 257B skidsteer stuck in some mud on a very steep hill. The skidsteer weighs about 7700lbs. The concrete driveway that I was parked on was the same one that I had problems with the tailgate. I backed the truck down to the middle of the driveway, and attached a cable to the skidsteer. One of my guys was trying to drive the skidsteer out of the mud while I pulled. I first locked the differential and put the truck in 4wheel drive low. There was dirt covering the driveway, and I started to spin the first try and had to sweep in front of the wheels. After sweeping in front the wheels I tried again. The truck would pull the cable tight and strain against the weight for about five seconds while the guy driveing the skidsteer worked his way out of the hole. The trucks engine would basically throttle back allowing the truck to role back and let the rope go slack. It would to this in a suring motion, like rrr....rrrrr....rrrr.....rrrrr. Jerking forward getting the cable almost tight and then falling back again. I tried again in four wheel drive high and it basically did the same thing again, but it was able to hold the original tension on the chain for about 10-15 seconds, before going into the suring motion. All the while this was going on the truck had enough traction that it couldn't spin its tires. The only time its tires ever spun was there was loose dirt under them.
Does anyone have any ideas?
Thanks,
Adam
Thanks,
Adam
