I replaced the rear left wheel sensor and while I was doing it I disconnected the battery in hopes that it would clear the codes from the bad sensor. I changed the sensor then reconnected the battery and she won't start, I just get a click by the fuse panel on the passengers side. I checked the battery and its fine, I went ahead and topped it off with my charger but its still not starting. I checked for loose terminals, took them off and cleaned everything, broke the positive connector in the process, picked one up at the dealer and replaced it. The gauges all work fine, no dimming or anything when I try to crank it.
I bought the truck used a few years ago and have never disconnected the battery before. Is there a security feature or something I need to do? Any help would be much appreciated.
