Are there any Titans out there w/an overdrive button? If not what's the equivalent? I used to have a Tacoma w/this feature if a wanted to speed up on the freeway I'd just press this button and take off ..
THX
THX
Depends on the situation. If I'm stuck behind some tool going below the speed limit and I need to get over to go around, I'll drop into 3rd before I do anything else. Why? Instant passing power, otherwise I'd have to switch lanes THEN get on it and sometimes that delay is enough to get someone on your butt.HudsonValleyTitan said:Why would you shift at all on a freeway? That's not what it's for. Wanna go faster on the freeway? STEP ON THE GAS!
Plant your foot and go...that's all you need for instant passing power. By the time you reach down and pop it into 3rd or 4th, you could have been 3/4 of the way around the slo-poke. I get on it, THEN switch lanes. Unless you're backroading and putting it in a lower gear to be right where the power is to pull out of a nice turn!Yahooligan said:Depends on the situation. If I'm stuck behind some tool going below the speed limit and I need to get over to go around, I'll drop into 3rd before I do anything else. Why? Instant passing power, otherwise I'd have to switch lanes THEN get on it and sometimes that delay is enough to get someone on your butt.
Most of the time I just leave it alone and pass normally, but there are times when that's not the best option. :upsidedow
Apparantly not, lots of folks are too lazy to read the manual and rather guess or be spoon fed the information/mis-information. ;-)Smoke05 said:Does no one read the friggin owners manual???? Jeez!
Actually - there are three - it's just a computer controling the third (it does have a clutch and traditional gearbox, just a very unconventional clutch acutator).Carbeaux said:![]()
"Real" sports car. Two pedals.
or just put it in 4th gear right ?Overdrive is built in. If you want to turn it off hit Tow Mode beneath the radio. This is the same as turning your OD off and will switch you back into 4th.
