1 - 6 of 6 Posts
DARAS193
Discussion starter · #1 · (Edited)
UtilityTrac bed extender?
Im Thinking about buying a bed extender and I found a guy that has one for pretty cheap, he has the Utilitly track in his bed and I dont. Will that be a problem for installing it in my truck if I dont have the Utility track?
thanks
I think the factory bed extender is for the Util-trak system..only...But there are several aftermarket ones around
I'll sell you mine for $100 with the brackets. It came with my truck and I have no real use for it.
the sliding bed extender that works with the utility bed package won't work on a non-utility truck.
you can however buy the correct brackets @ amp research. The non-sliding non- UTB package extender mounts bolt to where the factory tie downs are located.
installing the utility bed package is difficult on a non-equipped truck.
Discussion starter · #6 ·
So if I buy a utility rack from some one who has the ut bed and get the brackets from amp everything pretty much bolt up easy?
1 - 6 of 6 Posts
