21 - 40 of 59 Posts
Just do 3 dude. I wanted to be different and do 4 and it looks good but sometimes I think it looks a little crowded in there.
Just so you know I also used the FF's.
Wow, I really didnt think 4 would fit down there. But obviously I'm wrong. Thanks 08pro4x for the pics.
I have 3 Light force mounted on my bull bar and just from looking, not measuring lol, I didnt think they would fit. IMO, I like 3.
my bad the 3 go upside down ... i did my instaall like 3yrs ago i didnt remember
Discussion starter · #24 ·
So if I do 3 or 4, they both mount upside down?
No just 3 man. If you do 4 you will be mounting them right side up homie.
check this switch out i bought i $3 switch from oriellys matches perfect with OEM just cut a square out of one of the blanks and it slide in and it is very tight.
looks and feels Stock
Reactions: 25370
Discussion starter · #27 ·
Zach, how hard was it to run the wiring to that location.. Thinking about mounting my switch in front of my shifter, next to my tow mode button.
very easy to do just pop the radio head off be sure to disconnect the battery or you will throw codes, and i moved the shifter to 1 to have more room. then you can use a hanger to fish wire through the dash to either side footwell you can actually look in there and see the floorboard. hardest part was working the switch in and out without trying to pull off the part that holds the switches. i personally went through the hole in the firewall with the E-brake cable. just use a small flathead screwdriver to eaisly pop the radio head off. let me know if i can help any more
Reactions: d0va and pd298
Discussion starter · #31 ·
got it done today guys, only went with 3 lights. I was surprised by how bright they are after hearing everyone on here complain about their brightness. love the look, thanks for all the help
Lets see it!
Discussion starter · #33 ·
It was too dark for me to get pics. all i have is my blackberry for pictures anyway so they wont be that great
Lets see it!
Hey those lights look sick, wish i wouldve thought of doing that a long time ago, and now i'm not even gonna have my bumper much longer lol.
When you mount the 4 on the bottom there are the 4 remaining holes where the plactis was mounted. On mine the 2 inside mounts will need to be drilled out a little and the outside mounts are not fully enclosed they looked like a c. Did you have any problems in mounting the 2 outside lights. I am not going to use the black plastic housing at all. Also without the plastic housing there is no rubbing of the lights.
Looks good, where'd you buy your lights from / find a good deal on em?
That is correct. No I didn't have any troubles with them. They've stayed in place for a good 15,000-20,000 miles.
21 - 40 of 59 Posts
