I added 2 gauges to the overhead console. I love the amp gauge, but I must admit having oil run through the a pillar and up into the console is a little scary.
Where did you mount your tranny sending unit? Also, how deep are your gauges? Was it a tight fit? Did the upper console panel fit back in nice and snug? I have a a-pillar gauge pod but I would like to add oil temp and amp gauge where you put your 2.Thanks krh2, I will be monitoring the tranny temp very closely.
Part of my problem is I installed the sening unit in the hose just below the radiator while I wait to order my PML pan. I definetly suggest installing at the tranny. I will be doing that next month.Where did you mount your tranny sending unit? Also, how deep are your gauges? Was it a tight fit? Did the upper console panel fit back in nice and snug? I have a a-pillar gauge pod but I would like to add oil temp and amp gauge where you put your 2.
Thanks Kev
Thanks, I have that bezel and know of the gauge pod you are talking about. Would be cool if they made one. I mounted my sending unit in a pressure test port. Seems pretty acurate...Part of my problem is I installed the sening unit in the hose just below the radiator while I wait to order my PML pan. I definetly suggest installing at the tranny. I will be doing that next month.
The gauges are a little tight, but they fit pretty good. I installed the overhead console myself and I had to fab some brackets to attach the screws to in the overhead, so mine may have a little more room than other trucks. There are gauges that are a little smaller that would probably fit easier. Also, I am trying to get Lotek to make some gauge pods that go above the radio in trucks that do not have navigation. Do you have this bezel or navigation?
That is a really good idea. If you get the chance can you show me where the port is and how you installed the sending unit? Is the port threaded? If it is threaded is it american standard or metric?Thanks, I have that bezel and know of the gauge pod you are talking about. Would be cool if they made one. I mounted my sending unit in a pressure test port. Seems pretty acurate...
Thread on the sender is NPT, port is BPT or MPT I cant remember.. I kniew the sender was brass so it would strip the threads on it before the tranny port hole would. I put tephlon tape on it and gently theaded it and torqued to about 15 ft lbs. Went in easy, didnt bind, and no leaks. I would give you a link here to my total install but my forum is filtered/blocked here. Lemme try to find some pics.That is a really good idea. If you get the chance can you show me where the port is and how you installed the sending unit? Is the port threaded? If it is threaded is it american standard or metric?![]()
i too plan to add some gauges in the near future.. i haven't fully thought it through though.Thanks DeadRiver, speaking of frying things....the tranny gauge is the only one that varies between 125 and 190 under similiar situations. The water and oil temps always seem to run around 180. Anyone else notice the tranny temp varying like that without running hills or while towing.
Yeah, I like the gauges and they look pretty cool too.i too plan to add some gauges in the near future.. i haven't fully thought it through though.
lately i've noticed that my oil pressure dips to the low side when idling at a stop light. i didn't recall that happening when i first bought the truck and others report that it's normal.
This guy make his own two gauge pod,Do you know of any that make a one gauge pod for the Titan? I dont have the air bags in the A pillar so I'm good. That truck is pretty crazy dude. I couldn't even tell it was a Titan at first.
