First off let me say hi, I am a car dealer out of middle tn who specializes in late model rebuilts. Longtime member of ls1tech amd ar15.com, joined here after much google searching on a problem with a Titan I bought.
Low beam headlights do not work, fogs and highs work fine. All grounds are good, No wires or connectors have any damage. IPDM shows signs of abuse, and all relays were pulled/replaced at one time. Replaced switch on colum, no fix.
I do not get power to either side of the low beam fuses. 12v Jumper wire to the fuses directly makes both lights illuminate. I suspect IPDM is faulty and needs replacing, just wanted to get a second opinion. This is the only elec. problem with the truck, everything else works perfect.
2005 CC XE Off-Road
Also if IPDM is faulty, local dealer wants $209. A part no. or (pref. site sponsor) vendor would be great.
Thanks,
Isaac
2005 CC XE Off-Road
Thanks,
Isaac
