21 - 40 of 42 Posts
Yeah, I have nismo cat back with stock manifolds-cats & it's pretty dang loud.
So loud, that I'm considering going back to stock.
I'll see how I feel about the noise after my vacation end of Sept.
Loud? BUAHAHAHAHA!!!!!!
Try the Nismo catback with JBA LT headers and Maggotflow Hi-flo cats in the B's...
You'll set off car alarms. (Ask me how I know...) :eyebrow:
Unless you are flexfuel, yes. Your AFR will be off and most likely enough to be in the danger zone. Tuning is certainly highly recommended... at least if you want to keep the beast alive.
Warning first post here: I'm better with a wrench than a mouse.
I'd like to start off by saying thanks for the wisdom that has been shared here! There are many tips on this thread (and a few others) that are time savers. I have been planning this repair for some time and a large hail storm provided the cash. Thanks out to State Farm. Granted, my roof will never be the same, but it was worth it!
I started off by spending 2-3 hours removing the wheels, inner fenders and heat shields to allow for a week or two of PB Blasting on the header bolts and all exhaust bolts. I was able to get both heat shields off by cutting around the O2 sensors and doing a little bending. The passenger side came back and out the bottom. The drivers side came forward and up out the top.
I ordered with the Cajun B Stage 2 Kit and added the Ultraquiet resonator. Everything arrived pretty quick and neatly packaged. Jeff was very helpful throughout the process responding to EVERY text or email sent - and there were several. I have to thank him too for many time saving tips! Before you order somewhere else to save a few bucks make sure they 1-have them in stock and 2-are willing to answer your questions. The kit is not cheap but I felt like I got what I paid for and then some! I have a friend who got a cheaper kit to save money and it's nothing like this kit, hands down worth a little extra.
I gathered the tools I don't own like the O2 sensor removal kit, long extensions, breaker bars, and quality name brand wrenches. I figured if I was going to break a tool I might as well get a free replacement. The long 1/2" extensions were most useful for the motor mounts. It took all of it to get the drivers side motor mount bolts loose-that front/top was the worst bolt on the entire project!
The old exhaust came off pretty easily from the first cats to the tip. I used some heat on the O2 sensors and they popped right off. The passenger side was fairly easy. The drivers side header wasn't too bad it was the lack of access to the motor mount. I did not have to remove the motor mount or its bolts, just loosen them and jack the motor up about 1-2" Slip the old header and gasket out and the new ones in. I used a snap-on 14mm straight wrench on most bolts and the offset wrench on the others.
My recommendation is to double check the clearance on the drivers side header and the motor mount. I knew it was close but bolted it up anyway. Then realized it's VERY close. I can fit a credit card through it with some clearance but I'd like more. It's not hitting or making any noise at this point. If I could do one thing over it would be to grind some of the front/top portion of the mount off before re-installing. I hope I don't have to go back and do this later....I'll be monitoring it closely for a few weeks.
Overall I had around 16-20 hours working on it off and on for three days.
My first trip was to the local muffler shop to weld all the joints and remove the clamps. $50. May not be necessary, but I think it was worth it.
I've been working with Joe from Cajun B on my Uprev tune. Wow, don't skimp here either! This tune and the features of the software are incredible. Joe has also responded to EVERY text and email sent. A huge thanks to him too!
My truck is noticeably better. I don't know how many horses it added but I do know that it pulls my 3 horses much better. The bottom end power is as incredible as the top end. It's like driving a whole new truck!
I'm going to try to add a few pics of the tools I used, the clearance on the drivers side, and the final install. The clearance pics aren't very good quality since they look like there is contact, but its the angle of the camera. Limited to 5 tho.
Again, thanks for all the help on here and from the guys at Cajun B. Thanks to State Farm for financing. And last but not least, good luck if you're headed down this path.
Cheers,
Matt
How were the manifold nuts? Any issues removing them?
The manifold nuts weren't too bad. I sprayed them with PB Blaster before I drove it for over a week to help free them. The passenger side was fairly easy to get to. The driver's side was tough on my 4x4 due to clearance issues but I was able to break them all free pretty easily with a cheater bar or a small hammer. They all came off without issue. I'm not saying it was easy, but nothing broke besides the skin on my knuckles a few times!
The drivers side motor mounts were the worst, again due to lack of access.
Just did mine word to the wise it's all in the prep work with the PB blaster. Also don't make same mistake I did when you goto flash the base tune. Make sure the antivirus software is OFF mine was not an bricked my ecu fortunate for me I live one hour from uprev sitting here now they are recovering it. Joe was he biggest help in this process he called them an told them the situation an spent about 2 hours emailing possible solutions before he called cant express how good Cajuns customer service an patients are hats off to the Cajun fellas.
I had a shop install my JBA longtubes, I am running down the P2A00. the next step is changing the header gaskets and yes I will be using OEM and that is what was supposed to be used on the initial install we will see. OK can I slip the headers back to R&R the gaskets without lifting the motor??????
Thanks Bobby
Possibly? You might have enough room on a 2WD to slide them straight off and straight back on. I don't think I had enough room on my 4WD to do that to the driver side.
I know this is an old thread, but I'm in the middle of doing this project. I've got the motor mounts loose on the drivers side. That top front bolt was unbelievably difficult to get to. Even when its broke its a pain to turn. There is a little metal bracket that wont allow a universal joint to sit right with the sockets I have.
I also couldn't get the heat shields out - but I haven't bent them yet. I don't see any other way than to bend the crap out of them.
Anyway - just wanted to say this write up is still useful and thanks! I hate photobucket but the write up is great even without the pics.
21 - 40 of 42 Posts
