Anyone running 600 lbs springs ? I have a 2wd. Would they be to soft ?
Sent while Autoguide force closed
Yes it can...you will need less spring as you move the lower shock attachment closer to the wheel...you photo does show an issue...are going to run long shocks?...because simply bolting the shock in the picture to that mount is going to drop the front end of your truck...Does the geometry change that much when you move the lower shock mount a couple of inches.
