Dielectric grease on terminals
4.3K views 16 replies 7 participants last post by  c1971tra
Hey everyone.
Well I just installed 8 E3 spark plugs in my Titan about 10 mins ago and realized I have made a dumb, and amateur error...
I am not proud to admit it but I misread the instructions on my Permatex Dielectric grease and applied it directly to the spark plugs' conductor :teeth: and have realized that dielectric grease is NOT electrically conductive...
The truck runs on all cylinders but the question remains, should I go back in and wipe off the grease from the conductors?
If so does anyone have a reasonable solution for getting at spark plug 7 (?) (drivers side, closest to the firewall) my solution was to remove the dang cylinder head cover but that took eons to put back on. (seal kept coming off)
Thanks in advance!
#2 ·
If your truck is running fine, I would honestly just leave it? If its not losing power or throwing codes I wouldnt go through the trouble to take it all apart again. Also, I dont think youd have to take the cylinder head cover off, seems like too much work for just some spark plugs. Gotta be an easier way for you if you do decide to wipe it off anyway.
#3 ·
Agreed, the thought of the plugs not getting full spark energy drives me crazy. Why spend the cheddar on E3s if I am not giving them full spark energy. :bangit:
Im thinking one of those trick socket U-Joint adapters will allow me to clear the brake booster and allow the socket wrench extension to slide down the tube.
Yea, lol removing the valve cover was a lot of work with the wire ties, PCV hoses, EVAP hoses, millions of wires, and about 12 bolts to get out of the way. :tongue:
#6 ·
Thanks import2nr, I had the exact same thought last night and will do just that today.
bfrank, that was the link where I learned that dielectric grease is not electrically conductive. So wierd that the box says apply to the terminals but then says maintain metal to metal contact.
Thanks guys, Ill take care of that mess up after I rotate my tires. :read:
#9 · (Edited)
From my understanding, dielectric grease is really more about displacing moisture and dirt to help prevent corrosion and poor connections. The metal contacts will make contact through displacing the grease and remain clean and effective for longer with the grease surrounding it. As long as the grease isn't so thick that it is keeping the plugs from maintaining a proper connection (which since the truck is running fine, it obviously isn't), you should be fine.
Is Dielectric Grease Conductive? | eHow.com
Derek
#10 ·
Well I went back and cleaned up the plugs...I went out and purchased a 2nd 3in socket extension and it worked like a charm...the extension I was using before was too long to clear the brake booster as previously mentioned. Truck runs great.
Thanks for the input yall
#12 · (Edited)
No, I didn't even bother with the stuff. My old plugs were clean and Nissan has seals on the coil packs to keep crud out. There was a tiny difference in that she idled smoother and throttle response was a little bit more snappy. (idk if it was in my head or whatever but seems to me the difference was almost too small to mention)
For those wondering, the truck has just about 60,000 miles on the clock. I decided to replace the plugs now as the truck has is forced to run on fuel she doesn't like (oxygenated gasoline 10% fuel methanol) living where I do, it is impossible to escape this crap gasoline. Nissan says not to use it but I unfortunately have no choice.
For those unfamiliar with "oxygenated" gasoline, the refinery adds anywhere between 5%-15% "fuel methanol" to the gasoline, effectively adding chemical oxygen to the fuel which supposedly reduces emissions in internal combustion engines. My truck hates the stuff in the winter, she becomes reluctant to start when the mercury drops, but thus far nothing I can't handle! :eyebrow: Shes a BEAST!
#15 ·
Yes there was a significant amount of grease left on the spark plug connection. Now was it enough to inhibit the flow of energy from the coil to the plug? Im not sure...If the grease is indeed not electrically conductive the energy probably arced through the grease to the plug, or it just found a dry spot on the connection and used that.
No, I never reapplied the grease, even the way your supposed to use it lol. The stock plugs were clean, and the repair manual does not warrant dielectric grease to be used on the plugs, the rubber seals on the coil packs do a great job of keeping it clean.
#17 ·
Hey everyone, great news!
Well today when I was putting around town I wanted to see if the E3 plugs do indeed give better throttle response and a little bit more power...
I tell you what, from a dead stop I pushed the throttle to about 1/2 maybe a lil more and tripped the tires a lot eaiser than before...stock engine except K&N filter element (not intake kit) and the E3 plugs.
I recommend the E3 plugs to any Titan owner. Great stuff. :redblob"
