You can put me on the list for gears as well!
However, a few questions and concerns you might want to bring up. First of all, those ratios seem awfully low for our trucks. If a Titan's stock 3.36 BT gear is equal to a 4:10 in other trucks, won't a 4:10 and especially the 4:88 be way too low? That would be great for crawling, or the drag strip, but probley not for daily driving. I think most people would be interested in a set of gears that would take a lifted truck with 35's back to the same performance as the stock 3:36. Which would be in the 3:53 range. And maybe have an option for a 3:73 for those that want to go just a little lower. Also, another issue is the Titan's computer. I know that RB's Titan is having some issues going from his stock 2:94's to the 3:36 BT gears. So wouldn't the issues be even more so with a much lower gear? The problems he is having is that the wheel speed sensors and the tranny sensor are seeing different speeds and it's causing some minor issues with cruise control, shift points, etc. So what would happen with an even greater gearing variation? Now don't get me wrong, I absolutley do want a set of front and rear gears, but I want to know they will work properly first.
