I've got an '04 4x4 SE CC (built in Oct '03 - 1st Titan in Houston). It's in the shop due to broken pinion and ring teeth and has damaged the rear diff. carrier and gears. I want to replace the 2.937 (99% positive it is based on CC29 on axle and from reading other threads) with 3.73 gears from Richmond gear and eaton truetrac. I was told by 2 4x4 shops that I can simply disconnect the 4x4 switch or make sure the switch stays in 2wd mode and it won't do any harm. Is this true? I want to make sure I can keep the 2.937 front until I can afford to swap it later. Or, must I disconnect the front drive shaft to prevent any transfer case damage?
