Has anyone looked into the possibility of having some steps made at a metal fab shop and then just get them Line-X'd?
I like the look of the N-Fab and Go Rhino D2 steps, but I feel like they don't NEED to be as large or hang as far under the truck as they do. I feel like the upper nerf bar could us a piece of steel that is much, much smaller/lower profile and still comfortably support the weight and provide enough of a mounting point to weld on the drop down steps which are what you actually utilize as the "step" portion. Has anyone looked into this? Or does anyone know of someone in the Houston, TX area that could possibly give this a go?
I figure the mounting points are straight forward enough, they should be able to fabricate a pretty badass set of steps for around $500 or so, which is around what these things run anyways..
