spyder vs. oem ?
4.6K views 13 replies 6 participants last post by  spoolie
wondering which ones perform better, have better light output for distance and width/visibility in all conditions, rain, snow..., say both were equiped with same 4300 hid's high and low?
#2 ·
Spyder CCFLs SUCK! I've had so many problems w/these things (inverter boxes/CCFL rings failing in rain/moisture, to the projector beams having crappy cut-offs)
Go OEM or retrofit OEM. I'm in a bind & looking to retrofit my Spyders.
Pathetic,
Craig
Reactions: JB
#3 ·
LOL spiders are a joke. quality is way beneath OEM. Retrofit is the only rear solution. or you can buy spiders and then keep buyin every year or so when they go out or start leaking. then on top of it all. ur output with spiders is worse then OEM halogens.
Friends dont let friends buy ebay projector lights...
Reactions: JB
#6 ·
I have Spyders...because my OEM driver side leaked BADLY. Then, my Nissan provided/installed warrantied OEMs leaked-BADLY. Haven't had single problem out of them since going smoked out.
#4 ·
Junk versus OEM....keep your factory housings and purchase OEM projectors and HID bulbs/ballasts. Don't do China/ebay/HIDKIT conversion...it's all garbage.
Reactions: JB
#9 ·
No such thing exists from Nissan. You'll need to retrofit your own. There's a thread on here about it. SD_Titan does this retrofit & can customize them to your needs.
Craig
Sent from AutoGuide.com App
