No problem ... had coffee too late and couldn't sleep.
For the lift you'd be better off getting spindles right away. You can run your stock coilovers, or stock application ones, like the Icons, SAWs, or the 2" body Radflo, or any OEM compatible like the Bilstein HD with them, as well as leveling kits, and still use the stock UCA, unless going above their normal maximums. Sort of like a free 4".
Adding level kits to the coilovers is a bad idea ... check out these posts by PRG:
http://www.titantalk.com/forums/1193958-post36.html
http://www.titantalk.com/forums/1336280-post9.html
As for the offset on a 9" width rim, and how far the
rims would stick out compared to stock:
+18? 3/4" more than stock SE/LE rims, (an inch more if you also count the tires' extra width, which stick out about 1/4" more, as far as section width). You'd likely have
CST spindle rubbing with wide tires though with 5.75" backspacing.
0? Rims stick out 1.5" more than stock. Might not rub at the pinch weld. 5" backspacing. This would be my pick if I could run spindles.
-12? 2" more than stock ... pinch weld rubbing. 4.5" backspacing. Popular size for thr pinch weld mod, but shouldn't be too bad with 33s. With 35s even my friend's 6" PC stage 1 lifted Titan needed to cut a little with the old version of the 35x12.5R17 BFG M/T.
-25? Rims would stick out 2.5" more than stock,
for a 9" width rim, and would have 4" backspacing. Bad idea.
But if you're talking about the 20x10s then 3" more than stock rims, and 4.5" backspacing. In this case, the backspacing accounts for an inch and the 2" wider width accounts for the other two inches.
Btw, nice looking rims ...
