Overloaded Titan
9.8K views 34 replies 16 participants last post by  CharlienoX
Don't try this at home folks. I inadvertantly overloaded my truck today with a pallet of sod. I had no idea it would end up weighing so much. It is sand-grown and was cut very thick. As the guy was lowering the pallet in, the rear dropped wayyyyy down. I did not check it until about a mile down the road, because the ride felt like I had no rear suspension. I didn't. It was resting solidly on the bump stops. When I went over any road irregularity, the rear end would only bounce up, then hit back down roughly. I ran it about 5 miles, never over 30 mph. I was sweating bullets. I should have had him push it all the way to the front of the bed to better distribute the load, but was scared he'd bend up my bed.
The pics don't look so bad, but keep in mind my truck has 2" steel blocks on the rear end. Without them, there would have been virtually no space between the tire and top of the wheelwell edge. I almost didn't put back on the rear bump stops when I lifted it, thinking I couldn't possibly ever cause the rear to drop that far. Well guess again - good thing I did.
The shocks don't seem to be damaged. Apparently these new Rancho's had just barely enough compression length space to not bottom out. But I'd swear the rear is just barely not sitting quite as high as before. At least I did not break anything.
#5 ·
Yeah She's loaded up pretty good allright. Looks like your tires held out OK. Not ballooning out much. I've done stuff like that. It's always good cause everyone just stops and stares as you crawl along hoping nothing goes snap :eeeek:
The last time I did something like that I was hauling cut slate. I just had to take a piece in the house and weigh it. Turns out I had about 1800 lbs on it.
Cheif
#6 ·
Hey guys check this out.
PLANNING INFORMATION: Sod weight is approximately between 5 and 6 lbs., per sq. ft. - Sod is harvested in pieces, 16" wide and 45" long (5 sq. ft.) - Sod is a perishable product, therefore site should be properly prepared so that installation may take place immediately after delivery
So each strip weighs around 30 LBS.
http://www.amsod.com/planning.html
#7 · (Edited)
Kronos1965 said:
MikeH,
Just curious...
How much did you think the sod weighed?
I made a similar error hauling perforated pavers and put in 1200lbs in the back end!
I will shortly be installing add a leafs! :eeeek:
Mike
I've seen other trucks do it at the same place, but there can be a lot of variation in sod. I put down 6 pallets 2 weeks ago that were muck-grown, and it was much lighter than this stuff was. (I had it delivered.) Live and learn. It would have made a big difference if it was all the way forward in the bed, instead of all the way to the rear.
#8 · (Edited)
Not around here it's not. All I have ever laid has been roughly 24" long by 16" to 18" wide. It varies a little. Today's was 24x18 (3 sq.ft. each). After I laid it, I measured out the area covered and it was right about 430 sq.ft., so it was about 143 pieces. I'd say they were right about 15 lbs each. So that would put the pallet right about 2145 lbs. (Maybe even up to 2580 lbs if it was 6 lbs per sf.)
I HAD NO IDEA (TILL NOW). OOPS! :domohit:
#9 ·
OOPS! :domohit:
Oh, well that's not to bad. HAHAHAHA!!!!!!! :hahano:
#10 ·
What the heck is it supposed to be able to carry? Did I almost ding it?
#12 ·
1184 freaking pounds!!!! WTF!!! I'd say they have a little safety factor included in that.
Well, now I know my new blocks, u-bolts and shocks work well enough. Excuse me while I go faint. $hit, no wonder it looks a little lower now.
#14 ·
Squid said:
Still with us?
:fever:
I just went out and measured it. The rear is still 2-1/4" higher than the front. :D
The stupid little sticker in the door frame that talks about the tires says the combined weight of passengers and cargo should not exceed 1030 lbs. What's that about? Is that for the whole truck, or just in the glove compartment?
#15 · (Edited)
New springs aren't too bad. nissanparts247.com has 'em for:
4WD, Each, w/Towing Package 55020-7S411 $107.24
But this really looks like a Dever leaf opportunity to me. :D
Oh they sprung back. Well at least that's cheaper.
#16 ·
Mike H. said:
:fever:
Right about now I think you can throw away that sticker, and anything else that says anything about payload because you rewrote the book today. :cheers:
#17 · (Edited)
Yeah, maybe, but I'm not sure the bump stop weight capacity is supposed to be included.
#18 ·
That is cheap - maybe I should add a second set, side by side next to the original set.
#19 ·
LOL, I think I'd just go for the Devers at replacement time, since a pair of the OEMs will be almost 1/3 of the Devers.
#20 ·
Yeah, but are they "sod rated"?
#22 ·
I would not worry to much, especially if it is a short trip and you go slow, avoid dips potholes etc. I put a pallet of wood pellets in my Titan for 25 mile trips(2000lbs). I did the same thing with my Tundra. Just have to put the pallet in the front of the bed. I just wouldn't make a habit of it.
#24 ·
The payload cap. of the Titan is pitiful. My 85 Toyota has a payload of 1100lbs.
#26 ·
yeah the payload weight of the Titan is pathetic,next time add some air to the tires and leave the tailgate home so the pallet can go in far enough without getting to close for comfort.
