Radiator Problems on 04 titan
3.1K views 29 replies 23 participants last post by  onelowmini
Has anybody else had problems with their radiator leaking fluid. i noticed yesterday my 04 titan was leaking radiator fluid on my drive way just wondering if anyone else has had these problems? thanx
#2 ·
The Bottom of the Radiators are plastic, I have seen a few crack and leak.
I would recommend a Factory but Aftermarket is cheaper..
#3 ·
i had mine replaced some time ago. i noticed some dried coolant on the bottom while changing oil.
#7 ·
My '04 has a small leak as well, another one to add to the list.....rear axle, brake recall, leaking tranny line, rear seatbelts, 2 broken driver side power window motors, still love the truck, but..........
#8 ·
Buy a aftermarket for 1/3 the price. Even those who have replaced the factory one with factory replacement has had more failures. Nissan, like the differentials, cannot fix problems. Period.
#12 ·
Wow...felt like I was reading my own truck's CarFax report....
What was your rear-seatbelt issue? Mine is they snug up too tight on the passengers. I've had all the rest of your issues to a tee though
#14 ·
MishMash the rear seatbelts were recalled, so I brought my truck in not long ago and guess what they had ordered the wrong seatbelt!!! I love dealing with Nissan!
#15 ·
I had my rad replaced on my 05. Little dissapointed, it only has ~13,500 miles.
#19 ·
A lot of times it's just the radiator cap that's bad. There's even a TSB just for the radiator cap. I have an 04 and my radiator cap is bad. Very easy to tell if this is your problem...it leaves a greenish/white line from the rad cap down to the fan housing and also spits some coolant onto the top engine cover.
Very simple and cheap fix for me.
#21 ·
Got my radiator replaced under the extended warranty on Tuesday. Would have been about $650 without it, but then I would have gotten an aftermarket w/o the plastic part that cracks ... if I was paying. I finally got a decent rental out of the Enterprise the dealer uses.
Rental was a 3.5 liter Maxima which sux being that low to the ground, (after being used to being a little lifted), but it had great acceleration and cornered even better than my Titan with its aftermarket suspension. Extremely impressed with it. It had 245/45/18 tires, but still had a smooth ride for stock suspension and rubber band tires. Nicest sedan I have driven.
#22 ·
Rubberband tires??? that is stock issue and I agree with the rest of your findings. When ever I drive the wifes car I feel like I am dragging my arse on the ground but when it come to passing and taking turns I find myself grinning ear to ear. :teethmast
#23 ·
:lol: It's one of those subjective things, and IMO, 4.3-4.5" sidewalls are "rubberband tires" ... especially when compared even to the stock O.R. 33s, (P285/70/17), which have an 8" sidewall.
Btw, Tirerack has 76 different versions of models in this apparently very popular size!
#24 ·
I see your point now and here I always thought they were a pretty thick tire for cars compared to the lo-pros everyone installs nowadays.
#25 ·
I just replaced my 04's radiator 2 weeks ago, the plastic tank at the bottom developed a crack. I replaced with an aftermarket unit, I hope it lasts longer then the OE unit did...
Some GM vehicles a short while back had similar plastic tank issues also...
