Radio wont turn off
1 reading
17K views 10 replies 7 participants last post by  Myermat1
I have a 2008 Nissan titan with no mods all factory. It has the upgraded radio. When I got out of my truck today the radio stayed on. I unhooked the battery and reset everything but the min the ignition turned back on the radio wont go off. I'm lost cant find a wiring diagram anywhere online. I know there is probably a relay gone bad somewhere but I can not find out where. Please help someone..........................:confused:
#5 ·
Why is it when something odd happens to the radios on one it happens on several. lol. Are they the rockfords or just 6 disc?? Check to SE if the accessory power port shuts off with the key??
Can't just say it's a radio issue till you check. I'm not saying it's not. But there is no proof it is yet
#6 ·
Hey 08RedTitan - did you ever determine the root cause? My 08 Rockford Fozgate just did the same thing when I got home from a long trip tonight. Last time this happened I recall that by keeping something connected to the charger plug-in (in the back seat?) the same thing happened, until I unplugged the charger. That is not the case this time. I did the quick battery disconnect to no avail. Right now I have the 10A fuse pulled until I can look into it further.
#8 ·
Mine is a Rockford. I just left the battery unhooked over night and it reset everything haven't had the problem since. It wasn't just the radio the Bluetooth stayed on too. It was a relay under the dash that was sticking and causing it to stay on. Nothing was replaced just left the power off for a good 12 hours. Root cause it was about 115° heat index the week I had my issue. That's the only guess we had.
#10 ·
Indeed. I disconnected the battery overnight and it worked as stated; the radio stays off now upon shutting off the truck. Odd thing though, it wasn't an immediate fix. Upon first reconnecting, the radio continued to be powered on. I cursed. Then I drove it to the store and back and it "healed itself".
Thanks for the reply. Take care.
