Hey, I hope the pics help you out. Pretty easy install once you get down to it.
Later,
Chris
DIRECTWIRE™ WIRING INFORMATION - NISSAN / TITAN / 2004 / Remote Start
12volts = green (40A) + ignition harness
Starter = brown + ignition harness
Second Starter = lt. green or blue/green + ignition harness
Ignition = black/red + ignition harness
Second Ignition = N/A
Third Ignition = N/A
Accessory = red + ignition harness
Second Accessory = purple + ignition harness
Keysense = red/blue to black/red + ign harn or BCM R of column, pin 37
Power Lock = blue - driver door module in door
Power Unlock = red (double pulse) - driver door module in door
Lock Motor = purple 5wi BCM to right of column, pin 65
Unlock Motor = green 5wi BCM to right of column, pin 59
Parking Lights = + red/blue + dimmer switch on dash
Parking Lights= - N/A
Hazards = white/black - BCM to right of column, pin 29
Turn Signal(L) = green/black + BCM to right of column, pin 60
Turn Signal(R) = green/yellow + BCM to right of column, pin 61
Reverse Light = green/white + inside rearview mirror
Door Trigger = see notes - BCM to right of column
Notes: The LF door trigger is lt. blue in pin 47. The RF door trigger is red/blue in pin 12. The LR door trigger is red/yellow in pin 48. The RR door trigger is red/white or gray in pin 13. Use all four wires and diode isolate each.
Dome Supervision blue - BCM to right of column, pin 63
Notes: The blue wire is for the dome lights and puddle lights. For the step lights use red/white in pin 62 at the BCM.
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT white/blue or black ac any ignition coil
Wait to start N/A
Brake Wire = red/green or red/black + brake pedal switch
Parking Brake = green - parking brake switch or cluster
Horn Trigger = red/white - horn switch
Memory Seat 1 = lt. green/black - memory mod. left of column, pin 9
Memory Seat 2 = pink/blue - memory mod. left of column, pin 25
Memory Seat 3 N/A -
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: N/A
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
