Tranny Codes
9.5K views 7 replies 5 participants last post by  Roush
I am noticing my transmission is slipping. I hooked up a scan tool and pulled two codes from the transmissions computer.
P1705: Undocumented Code
P1815: Manuel mode switch circuit no up/down signal
Took it the the stealership and one of the techs is saying the transmission is possibly fried. Might need to replace. He took it for a test drive and we are going to further diagnose tomorrow.
#2 ·
P1705 Throttle Position Sensor (TPS) [Accelerator Pedal Position (APP)]
Description
Electric throttle control actuator consists of throttle control motor, accelerator pedal position sensor, throttle
position sensor, etc. The actuator sends a signal to the ECM, and ECM sends signals to TCM with CAN communication.
Possible Cause
Harness or connectors
(The sensor circuit is open or shorted.)
P1815 MANUAL MODE SWITCH
Description
When an impossible pattern of switch signals is detected, this is judged to be an irregularity.
Possible Cause
â—Ź Harness or connectors
(These switches circuit is open or shorted.)
â—Ź Mode select switch (Into control device)
â—Ź Position select switch (Into control device)
#3 ·
Already took it to the dealer. They said the warrenty is voided cause I didn't service the tranny at 30K miles. Its got 37XXX miles.They said I need a new transmission because the oil is burned up. Service Manager is going to try to push it to get it covered under warrenty but isn't promising anything.
#4 ·
NISSAN TITAN, transmission shudder, 3 x to nissan, they "RECOMMEND" a new torque converter and transmission, when I asked why they said they are one and the same. When i called BS they said "we recommend a new transmission mission" first 2 trips there was no code and now they say say code P1867 which I can not find anywhere online for nissan, but it is a code for a ford 150/250. any one been lied to?
#7 ·
So I had this shudder in trans on 2017, took to Nisaan 3x as previously posted. First 2x no codes, they did nothing. 3rd x they feel shudder and then tell me I need a transmission at $8404. I had been saying to flush or change torque converter. I got some story about the torque converter is the transmission. They think when they see a "retiree" it is a gold mine. I asked what was wrong that I need a trannie. they said it is shuddering and no way to fix. So I take it to a local trannie shop and the fluid is blackened not burnt. As you all know there is no dip stip for the tyrans on a 2017 /I asked them several times to perform trans TSBs everyone here posted. nope, they want $800 to do that and they say it wont help. okay back to the shop, they drained the trans, flushed and charged me $660. Yep $660 and the thing runs better than I ever remember. It was fluid, fluid, fluid. CHANGE YOUR FLUID EVERY 30K. What a rip off ... so now I am writing Nissan, no Amer, the dealer, local news outlets (all3) and consumer advocate at state level and DAV. F'ed with the wrong Marine! this may go nowhere but I sure hope it gets on the news.....
#5 ·
The torque converter is a huge problem on the aramada, which uses the same engine and speed as the early second gen trucks. Have them scope and see if your is cracked or bad
#6 ·
