has anyone looked into a way of pulling a fuse or somehow getting around the VDC, or removing it altogether???
i forget what it was called (the black with the rainbowWas majestic black a new color option?I just LOL'd..........
If you don't have the VDC switch, you don't have VDC...No i have no button for traction control (vehical dynamic control) XE FTL.. i guess im talking about the slip (ABLS) there has to be away to elminated this through the ECM. maybe a wire pinout or some way to create a bypass.. who are the wizards on this forum?? nobody has tried this yet..???
thankyou thats what i was looking for...If you don't have the VDC switch, you don't have VDC...
There are several well discussed methods to dis-able the ABLS(Antilock Brake Limited Slip)
1) For a quick try - On flat ground, put in neutrual, apply park brake, and shut off the truck. Dis-connect the brake switch on the brake pedal(there are 2, dis-connect the lower one, close to the pedal pad) Fire the truck back up, slip into drive and no give it a little brake and gas and watch how much white smoke is released from that poor rt tire...HERE'S the disclamer...WHEN YOU DO THIS YOU WILL NOT HAVE ANY BRAKE LIGHTS AND ONCE YOU PUT THE TRUCK IN PARK, YOU WON'T BE ABLE TO GET IT OUT UNTIL YOU HOOK THE SWITCH BACK UP...
2) Do a search for which wire runs to the ECU(I think it's the wht with red tracer) and open that circuit and install a switch mounted in the dash, you can now turn it off on the fly, as well as getting your brake lights back on with crawling inder the dash...
I did option #1 the day before buying new tires...
yea as long as the switch is on,in option 2 do u loose brakelights still with the abls off?
Actually, no....By installing a switch right before that wire goes into the ECU you "catch" it after the brake switch...in option 2 do u loose brakelights still with the abls off?
For detailed instructions, search "Burn out mod"....so how would u install this switch??
Technically you are correct, the "burn out" mod doesn't do away with the ABLS, but it will alow the drive to use the brake to get the tire(s) "lit up" easier...The "burnout" mod does NOT disable your ABLS.
