1 - 20 of 45 Posts
JauntyBishop
Hey yall,
I would like to see some aftermarket B-pipe to Y-pipe Setups, or really any under carriage exhaust shot to the aftermarket Y-pipe you guys have.
Preferably the Flowmaster Y-pipe and Magnaflow Y-pipe, or if your're baller, a Burns Stainless design.
Thanks!
Discussion starter · #2 ·
Btw, i just wanted you all to know as of 4:51 am in florida time, the first 14 threads after the last "sticky'' i am the last poster lol... i was thinking of doing the whole page, but you guys would probably freak out...
saying like "this Milenkogt is F'n google searching info sourcing non sleepin thread postin fool...son"...lol.
Here's my magnaflow DI 2.25"/SO 2.5" ypipe. I don't like the location of the ypipe but it works for now. The guy said that it was the only way he could make it work.
Sent from my iPhone using Autoguide
I just found these couple photos of the y-pipe I built. I couldn't find any photo's of the finished product off the truck. It's 2.5, merging at 10 degrees, into 3 inch oval to 3 inch round. It goes into a 3 inch bullet muffler then dumps before the rear axle, but just yesterday, finally tired of the drone, I installed a dynomax vt muffler and am waiting for some bends to come in to do a side exit before the rear tire. I'll try to find some more photos, or climb under and take one if you want.
Ohhh now you make a thread...
I just posted all my pics in the other thread.
Hold on i'll get them. :bangit: LOL
This is from the initial install:
I think the guy could have done a better job, but it was CHEAP! ;)
Just took these. Its getting kinda dark outside not the best lighting. Its been storming all week:
The straight piece of 3" pipe after the Y-Pipe is the only piece left of my Banks Catback for now.
I sold the 3" Y-Pipe, but i still have the over the axle tailpipe section & 5" tip! ;)
Sounds even better than it sounded with the Banks Muffler!
I pretty much want to have it completely redone from the B-Pipe flanges to the Y-Pipe.
No crush bends, just smooth transitions all the way back! :eyebrow:
Discussion starter · #10 ·
Nice setups guys! I really need to get some better 90deg bends after the B-pipes going into my Y...
Is there a way to not have a huge bend on passender side after leaving B-pipe going into the Y-pipe? Mine has it, which is similar to Gweasels.
However, most of you guys 90deg bends coming from the drivers side are a lot better than mine lol. I just need a welder and some time...
I'll get pics up later sometime. I have stock pipes:( to flow master y directly to the banks.
HMMMMMM!! What size pipe is that on the catback? Arnt you the fastest Titan on the forum? Just wondering...lol :)
LOL....2.5 from the headers to the Y pipe into 3 in tail pipe....I'm one of the fastest on motor behind toomanymods 12.92 titanss 13.18 and me 13.36....but that will be changing before years end
He stole this set up from me :smileysqu click the link in my sig and you can see my set up, i just need some headers and i'll be running firelife's times :coolsmile :rofl:
haha.....dammit dont give my secrets away.....
it's ok i stole it from DeerSlayer... :rofl: Maybe hit your times if i had that new GTM set up :coolsmile
Coming after you myself!!:bump: Just need to rid myself of the stock manifolds and cats. Some traction help and weight reduction would also be nice.
Good luck!!!
I know you mentioned it already, but you should really look into getting your Y relocated as far forward as possible when you get a chance.
Like this:
Reactions: WIKEDVK
1 - 20 of 45 Posts
