How to start a Titan without a registered key and not void the Warranty.
62K views 32 replies 22 participants last post by  rwilsonswan
#1 · (Edited)
Hi All, I have read Numerous threads on the frustration and expense related to the requirement to Register Iginition keys with a vehicles Anti Theft System.
So I figured out how to beat it without modifying the vehicle or software.
background:
I recently purchased a 2011 Titan which is certified preowned with the extended warranty service contract. So it was important that I not void my warranty.
They only gave me one Key and FOB (note to anyone buying a used Nissan, be sure to find out how many keys/FOB's your getting and if you need more to negotiate them as part of your deal BEFORE you sign on the dotted line).
I purchased a bunch of FOB's on Ebay and programmed them using the easily searchable procedure on this website and they work perfectly. The keys are another matter.
I called my local dealer (different then the dealer I purchased the truck from) to inquire about extra keys...
100 bucks for the blank
100 bucks to cut/register it
:huh: which turned to :crying: which turned to :read: which turned to :eyebrow: oh it's on Nissan...
To immediately mitigate the risk of losing my only key and turning my pretty new truck into a 7000 pound parking ticket holder I sought after a second key.
Turns out that Ace Hardware can cut and register keys for Nissans. It took the key maker two attempts to get it to register but it worked. They charged me $80. Much better then the dealers $200, but still a bit of a sting when I'm used to paying $3.19 for a little metal bumpy stick to make my wheels go.
Plan on about 20 minutes for the key guy to walk back and forth to your car a few times (you should park close to the store). I would also call ahead and confirm that they have a "certified chip key associate" in the store at the time of your visit.
While I was there, I also had them cut me two non transponder keys for possible experimentation/lockout contingency.
My goal was now to figure out how to get the titan to start with a non transponder key, while not altering anything that would void the warranty.
After some research I figured out that the antenna module that interrogates the key is just behind, underneath and slightly to the right of the hole that key goes into.
I removed the plastic dash panel under the steering wheel (two Phillips head screws on the bottom and just pulled the top straight back to pull the plastic snaps out).
Then I removed the metal panel underneath (4 Phillips head screws).
I then repeatedly attempted to Start the Titan with a non chip key while holding the Ace Hardware registered key underneath the now exposed ignition column. It took a few tries but eventually I found a sweet spot. While holding the registered key in place I managed to slip some zip ties around it and very securely zip tie the registered key to the NATS antenna module.
I double checked that it would still start, which it did. Then put the dash back to together and check that it would start again, which it did.
Here is a shot of the key zip tied up under the dash from the view of the gas pedal. It's zip tied to a small black box that is the NATS antenna module (sorry didn't take a pic before attaching the key)
Here is a reverse shot, you can see the plastic square that receives the plastic panel directly below the ignition as a point of reference between the pics. (Note, that the key in the ignition is a non transponder key and starts the Titan if turned).
I now have a Titan that will start using keys that only cost 3 bucks to grind, and FOB's that only cost 8-10 bucks on ebay.
As for security I noticed that even with the registered keys, if I don't unlock the car with the FOB first then it won't start. I also can't shut the alarm off with the registered key, only with the FOB. Long story short, my Titan won't start without a Programmed FOB. If I ever lose a FOB/keyset I can always "deprogram" the lost FOB by running the FOB programming procedure with my remaining FOB's (of which I have 4 of, the max the truck will allow).
I hope this helps those out there who are just plain annoyed/appalled by the ridiculousness of the NATS system and the cost of keys. My truck gets used by several people and it's convenient that they all have a key (not to mention a spare). We also seem to lose about one key a year on average. If I had to do this through the dealer it would have cost me 600 bucks just for keys, and I didn't even ask about FOB's. It would also cost me about 200 bucks a year on average to replace the keys that we inevitably lose, plus the cost of FOB's. With this "hack" in place it now cost me about 15 bucks to replace a lost key/FOB set, and I can do it without a dealer appointment. I've already had a few extra non transponder keys cut at ACE Hardware and am ordering two more FOB's to have on hand to replace the ones we will lose with minimum inconvenience.
I also noted that you only need the transponder near the NATS Antenna during starting, once the Titan is running you can remove the registered key from the ignition area and the truck will still function normally with only the non transponder key in the ignition.
Good luck all, happy hacking!:hi:
#2 ·
Ingenious. Thanx.
#10 ·
How easy is that to do? Does it also disable the Alarm system?
I was also worried that Nissan might figure it out and give me the run a round:
"sir, your leaf spring broke because you tinkered with the ECU"... Or something like that.
Uprev is on the "truck list" but baby needs a new tool box, Rhino Liner and Undercoat first (I live in the Northeast US and winter is right around the corner).
#5 · (Edited)
Back in the early days of remote starter and "chipped" keys. There was no such thing as key bypass module.
Installer would have to use one of the "chipped" key and do what you did. Attached it on/near the ign key cylinder.
Even when they did have key bypass module, some of the early module required you to run an antenna wire
to the ign key cylinder and attached it somewhere that get read.
#6 ·
Another easy solution, I bought 3 non chipped keys for a total of $6, they will unlock the truck but not start it. I have an extra chipped key hidden inside my truck, only I know where it is, not an easily found location. I keep a non chipped key outside the truck, again not easily found, you would have to know where it is to find it. In an emergency, I can always get into my truck and start it.
Reactions: fish and GRAVITY
#15 ·
Nice mod. I have a remote start, but it only bypasses for a split second while the truck starts. This is a cheap option for many people
I was able to find a guy who will cut and program unlimited number of keys for $45. I bought 2 blank chipped keys off ebay for $12 and a flip key.
#17 ·
Disabled my one with Uprev - worked perfectly (although my NATS warning light stays on permanently now...)
#19 ·
I tried this tonight with my new 04 KC Titan and had no luck. I noticed you said you used the ACE key to Ziptie to the antenna. I guess they are just a clone of the factory chipped key, so it should have worked with my factory key as well, right? It didn't, but I didn't make sure I had unlocked it with my only FOB. I was nervous about getting locked out since my locks seem to randomly lock themselves over and over.
Just wondering if I should try this again or go with the plan the other person mentioned about hiding a backup $80.00 chipped Ace hardware key someplace in the truck and another outside/under the truck.
Thanks,
Jaime
#21 ·
That is awsome. WOW! Thanks man.:redblob"
#22 ·
This ain't anything new folks. This is what you did when you installed remote starters.
#26 ·
I must have not tried hard enough to find the sweet spot, I basically just made sure it was touching the outside of the metal sleeve and thought it would pass the electrical code through. I think I will try it again, and try your trick as well with hiding the other key.
Just to be sure, the thing you are zip tying the key to is the metal sleeve/cylinder that the ignition key gets put into, correct?
#27 · (Edited)
Ah ha! Your in the wrong place. Read the original post very carefully and look at the diagram that I posted. The NATS module that interrogates the key is attached right on the bottom of the cylinder that you insert the key into. In my truck it's a little black box (red arrow pointing to it). They key has to be against the black box.
Remember the NATS key interrogation module was designed to read a key that's in the key hole. Theoretically the black part of the chip key (were the transponder lives) has to be as close to the front of the key hole as possible.
The transponder in the registered key transmits a radio signal that is probably only readable not more than an inch, inch and a half from the key. So the sweet spot is really the point where you would get the chipped key as close to where it would normally be in the ignition but still have it be behind the dash panel, up against the black box.
Hope this makes sense, make very small 1/4 inch adjustments in the key position each time you try to start the truck, and be patient. Keep in mind that security system that took years for some very smart people and millions of dollars to develop. ... And your hacking it with an 80 dollar key from ACE and two zip ties.
Good luck.
#29 ·
Tried this, failed couldn't bare the sound of my truck not starting immediately anymore lol, dealer wants 128.00 out the door with tax in Florida, mobile service wants 95.00, trying to program the 2014 Nissan Rogue key
#30 ·
Best answer of all .Common sense applies .Thanks for the thread .Just replaced a 13 year old ignition key cylinder . Now i can take off the momentary and on off switch i fabricated to work. Doing some needling around i figured out how to use your factory faub lock/unlock/window control wireless to start this bad *** Titan as well. This Truck is bullet proof .:laugh:
