TPMS (!) comes on when on highway
1.4K views 6 replies 5 participants last post by  jdubslopro
Have 285/65/R18 Toyo Open Country A/T, running at 40 psi. TPMS light comes on after about 20 minutes of highway driving. Does not come on when driving around town. Ambient air temp is 50-60F. Any ideas as to what could be causing this? I'm not sure if the light turns off on its own after a while, but I do know that if I turn the truck off and back on it clears the light.
#2 ·
Not sure, I have basically the same thing occurring on mine, which doesn't even have the sensors installed.
#3 ·
What year is your Titan?
04-05 (!) light only mean system malfunction, (!) light with audible alarm mean low PSI in one or more of your tire.
06- current (!) light only mean low PSI, (!) light flashes for one minute at start up and stay on mean system malfunction.
06 and newer has no audible alarm.
#4 · (Edited)
sounds good, it's an 04...wonder what the system malfunction could be. I poked around a little and I saw that instead of running the TPMS wire through the grommet attached to the bed, it was zip-tied with a yellow zip tie a couple inches away from where it should've been...but I don't know why, the wire was intact...
#6 ·
I've had the same problem from time to time. It seems to come and go as it pleases. I have and 06.
