I finally got around to opening up the failed diff.
http://austinm.net/titan/diffinternal
As I said on my website, in my opinion, differential failure was caused by weak spider gears (differential pinion gears) alone.
The diff carrier housing is stout, the carrier bearings are fine quality, the ring and pinion are very stout, there are tight tolerances inside the diff carrier including spider gears to side gears, spider gears to spider shaft (cross shaft), spider shaft to carrier housing, etc. The spider gears are simply the weakest link, and they gave out.
Here's a couple pics - many more on the website.
The infamous pin for the spider shaft. This is what Four Wheeler magazine said caused their diff failure - the pin sheared. While I'm too nice 'a guy to throw a BS flag, I will say that this pin is more than adequate for what it does.
New paperweights:
New paperweights:
