Front wheel center hub nut size?
43K views 10 replies 8 participants last post by  nicolasmckoy
Front wheel center hub nut size? Does any one know? Tired to search but no luck :ftard:
#2 ·
If you mean the one on the axle shaft, its a 32mm.
#4 ·
Went to go replace my CV boot and had to rent an axle nut kit from advanced. The 30mm wouldn't fit and the 32mm was super sloppy.
Can someone verify the size before I buy a single 31mm axle nut?
#3 ·
54Warrior,
Thanks, that be the one.
Where did you get that skid plate in your pictures?
Thanks again!
Fredy
#5 ·
That's strange, I help a fellow Titan jockey change the CV axles and the the nut was 32mm.
L
#6 ·
I must have had an American made 32mm then, because it was ridiculously sloppy on it. I didn't want to use it.
What are the chances it has been replaced once before and they put a different size on it?
#7 ·
That could be possible.. Had a Nissan SER a long time ago that also used a 32mm, brought a reman. axle with a slighty different size nut.
L
#9 ·
I used 32 . Little sloopy but u wont round off nut because its a large size .
Sent from my SGH-T989 using AutoGuide.Com Free App
